Perkins M20 Starting
35
- - Pensacola, FL
I have noticed since purchasing my 1994 C270 with the Perkins M20 diesel, that the engine does not start as easily as I would expect. It seems to take a lot of throttle advance, and cranking for a few times prior to firing. I read in the manual to drain the wet muffler if having difficulty starting. I did that, and the engine fired right up. But it seems that having to drain the muffler every time would be a pain. Do others have to do this? Once it starts, it runs really great. Anyone else have this same situation with their Perkins? Any suggestions?
Catalina 320 Dana Point
You do need to give it a lot of thottle, probably
80% of WOT. Count of 20 for the glowplugs then hit the button, it does need to crank a little but shouldn't need to drain the muffler unless it takes more than 30 seconds of cranking. I haven't drained the muffler in over 2 years & over 200 hrs. run time.
