jtmccue
yatch specialties pedestal partsI have an early H28.5. The pedestal's "!plastic!" housing (Y321-0110) thru which the throttle lever's axle travels, broke/cracked. It just busted out of the whole that holds the axle which also keeps the lever mounting for the cable on the inside.Are these "housings" available anywhere or do I need to try super glue it, then drill in to make a stud - then reinforce the fitting with some fiberflass screening and pack it with autobody filler.Anybody have this happen to them and what did you do??
