The batteries in my Pearson Wanderer are jammed all the way up against the main bulkhead in the starboard cockpit locker. The battery box isn't securely mounted and let's not mention the wiring. Checking the fluid level in the cells or adding water is a nightmare. I have to twist sideways while hanging head down in the cockpit locker like a bat.
I bought a Guest charger just so I could remove the old charger (it's the big red box to starboard) and move one battery into the engine bay but there's no room for the second on that side. There's room on the port side, but I'm concerned about the length of the wires. I'd like to keep the weight as low in the hull as possible but the bilges are narrow because of the centerboard and the settees are low and too far forward. Any location must be accessible so battery fluid can be checked regularly. Any help or suggestions would be appreciated.
Thanks in advance,
Thanks in advance,
