Pearson 34 centerboard
Nov 5, 2010
99
Oday 23 Stonington, CT
There was a post here asking about this but is ended without much help. I am new owner of 1984 34' centerbd and need info on routing a new cable and where the axle pin/bolt is in the keel as I may want to drop the board. Thanks
NYSail
Jan 6, 2006
3,187
Beneteau 423 Mt. Sinai, NY
Easiest way to route / replace cable is to lower board, disconnect cable and then spice new cable into old.... then slowly pull from the top until new is threw. Then reattach as needed.
Regarding the pin, while the board is hanging down use a thin piece of wood, maybe a yard stick and slide it up the trunk until you hit the pin. Then use that to match the outside of keel as a best estimate and begin to sand..... you will eventually find the pin location. But why do you need to remove it?
good luck
