Has anyone replaced their cutless bearing on a 303? Since the shaft does not use a strut this appears to be a little more daunting. There are two set screws that need to be removed, but is it imperative to remove the shaft? I have an engineer friend design something to slide over the shaft from the engine compartment to press out the bearing that way. Are we being overly optimistic?
Any and all advice or critics appreciated. Cheers.
