Ray Rothaug
Shaft coupling
One must be a contortionist to check and tighten the four coupling boltd. And, you cannot use a socket wrench due to the tight clearances. Two open end wrenches must be used, one behind the coupling and the other through the side access door, doing an eithth of a turn with each tightening.
