Can someone tell me if there is anything I should use when installing a new paper gasket (lubricant/gasket sealer)? I am replacing the zincs on my Yanmar 2QM20 and the covers didn't have any paper left on them much less zinc. The PO said it had been several years since they were replaced. The zincs were disintegrated. Also, does anyone know what you call the tool used to remove the two hose connections that connect to the cooling water cylinder inlet connection? Once I pull off the hoses the pipes (1/4 or so in diameter) have these groves in them one at 12 one at 3 one at 6 and one at 9 o'clock. It looks as though a screw driver could be used to back them out but it would have to be a big slotted screwdriver. Did I mention the screw cap that holds the zinc in won't budge and this inlet connection turns when I try to unscrew it until these two pipe fittings hit the manifold? This is why I can't back the inlet connection out because these two pipe fittings are getting in the way. Does any of this make sense? Here is a picture I pulled from the internet. Of course a big screw driver would not work because the motor block get in the way! So where do I get a tool to do this job and what is it called?
