Has anyone painted the exterior wood instead of varnishing ? Kind of tired of refinishing brightwork and think boat paint would last longer. Uv rays are deadly. What results have you got painting instead of varnishing, polyurethane etc.
Looks good. My teak was 45 years old and rotten/worn out. Didn't want to drop $700 in materials and have to keep up brightwork so I went with Azek. The synthetic is a lot easier to work too.J,
Don't paint it, you will be disappointed. Because I say "life is too short to do your own teak", I recently changed all the deck teak to a synthetic PVC using their deck board and facia. The product is called "Sensibuilt".
This is but an alternative. Here are some pictures of the product pal.
CR
Fine 120 grit?JR,
Now here's the great part. When dry, your teak will look like sandlewood. The Snappy Teak raises the soft hairs of the wood, and if your wood is not weather-worn a fine 120 grit is usually sufficient.
CR
