Any other symptoms?
Are you looking at a tack or listening by ear? If it's leaving a black streak behind the boat it could be a number of things; mixing elbow, fuel filter, air leak in fuel line, dirty hull, wrong prop pitch, boat overloaded, overtightened shaft packing, transmission- hope not. Start by checking if it reaches full rpm's in neutral, then go from there. After that throttle up to full power tied up at the slip and see what it does. If it only does it while out running look at prop or hull fouling or prop pitch. If the linkage is working like Terry said, start with the fuel system first.
