FAST CASH
Hello,I put a 4 stroker on my 22 by the following method...Take the motor off, go below and loosen off the mounting nuts, press a piece of box cardboard against the bolt to get a drilling pattern, get a 3/16 to 1/4 piece of alluminum that is say 6 inches square around the drilling pattern, drill it, bed it SikaFlex, crank up the nuts...I imagine this quickie to be good for a few more pounds, I also epoxied in some roving at the hull to deck and transom tabs as the transom on mine is not cored to the very top...Quick, not so dirty, you can cut aluminum with anything that will cut wood, just wax your blade...Shutup Sean...SH.
