Outboard engine bracket
263
Hunter 36 Cobb Island
I was installing an OB engine bracket on the stern pulpit and the bracket says to use it on a 2 stroke engine only. Why would that be? What difference does it make?
K
Ken
No diff
Generally 2 stroke engine is lighter in weight to 4 strokes. So if you determine the weigh of a 4 stroke is non issue than no difference what you put on the obm mount.
Jul 8, 2004
361
S2 9.1 chelsea ny
there is a difference
the difference is in the torque of a 4 stroke vs. a 2 stroke. If you put a 4 stroke outboard on an outboard bracket made for a 2 stroke, over a (rather short period of time) the torque of the 4 stroke motor will start to damage the 2 stroke bracket.
May 24, 2004
7,213
CC 30 South Florida
It is the weight of the engine and its distribution.
2 strokes are lighter for any given HP size and they are usually less top heavy than 4 strokes. Make sure your mount can handle the overall weight and also the torque or lateral forces of the powerhead. The engine clamps protrude above the pulpit rail and can crack if subjected to strong lateral forces either back and forth or side to side depending on where the it is mounted. Stay under the rated limits when using a 4 stroke.
Manny
Oct 5, 2006
983
Hunter 82? 37 Cutter Wherever the wind takes me
Mike's right
It's the torque that can cause damage to the mount. Manny
Jun 4, 2004
273
Oday 25 Alameda
rail mount pad
WM has a simple rail mount pad in two versions; one for 2 stroke and one for 4 stroke. The main difference seems to be the size of the pad as well as the weight rating.
