Other options for stern ladder
Don
I'd like to open up the transom for easier access to the dinghy but the ladder gets in the way, esp when the dinghy is up on the davits. Anyone have a good alternative to replace the oem ladder with a folding one which fits the dimensions of the existing hinges? (H 40.5) thanks
204
Hunter 420 Punta Gorda, FL
Windline Slide Mount Telescoping Ladder
Our 420 was factory equipped with a Windline (Lewmar Company) folding ladder. You can see a picture at the link provided... http://www.boatersoutlet.com/index.asp?PageAction=VIEWPROD&ProdID=1733 It pulls our from the swim platform and swings down into the water and extends out 2 or 3 ladder steps. Might work for you. Good Luck, Bill
Don
Rich
I've only done it (paint) once - it depends on where in the yard it sits when hauled and we generally don't haul for winter. If I were going to haul every year, I'd be inclined to do it your way but the white paint serves as a good indicator color for the first coat of ablative to see when I get breakthrough on the top black coat of paint. The pic was taken last year when hauled as I needed to repaint, install another thruhull and also repack all the seacocks. Hope to get other ideas as these folding ladders typically don't fit - I may try something like quick release pins on the base bracket for easier access
Feb 10, 2004
4,248
Hunter 40.5 Warwick, RI
"Repack the seacocks" - What is this?
Can you explain this? If this somehow lubes the seacocks and makes them easy to turn, I am all ears.....
Don
Two options
What I was referring to was taking them apart (yes, I am anal), cleaning and re-assembling them after lubricating with the thick teflon grease. Usually all I do annually is squirt some waterproof grease in and turn them a few times which seems to work fine except mine were getting a bit harder to turn despite my routine weekly opening/closing at beginning and end of each trip or weekend. (except the one under the sink - the PITA one!)
Rick D
Jun 14, 2008
7,206
One Option
...which may be the one you are considering is to cut, sleave and fast-pin near the hinge. I saw this on a Catalina, and it worked well. RD
Jun 12, 2004
1,181
Allied Mistress 39 Ketch Kemah,Tx.
Side Ladder
Ever consider boarding from the side of your boat instead of the stern? I like it much better. Grasp onto the shrouds instead of the rails when getting on and off.
