Planning to install a double line reefing system which will have the lines led back to the cockpit.
I have been researching this for a while and decided to follow the diagram below on where to place hardware.
Is block B under the boom near the gooseneck the best place for it? Seems the pull on the mounting screws would be tying to pull the screws out. Mounting another cheek block on the boom or even the mast would put side pull on the screws and that would be stronger.
Any thoughts or suggestions on a better way to layout the hardware?
