Chuck , O'Day recommended
that the rigging be hand tight. They disclaimed that if the rigging was over tightened, it would damage the boat.I had a hard time with that for a while but it allows the boat to respond, the chain plate to the bulkhead to the pressure the bulkhead put on the deck. If you crank everything tight all the time, the deck distorts and the bulkhead are stressed. I would hand tighten the shrouds so that when you grab them about 4 feet off the deck that there is about 1" of play. When sailing the leeward shroud will sag.As for the fore and back stay, you will need to tension them so that the foil of the CDI does not have a lot of sag.( this will make it hard to furl) Testing the back stay, you will probably find that it is just a little bit tighter that the shrouds.Outer shrouds should be a touch tighter than the inner shrouds.This theory goes against the Loos gage. But remember I would rather do what the boat MFG recommended than some one trying to sell tension gages.Rule of thumb tighten the fore and back stays to about 75%. Tighten the outer shrouds so that the mast is plumb. Tighten the inner shrouds while sighting up the mast to keep the stick straight. Then finish off the fore and back stays tensioning.r.w.landau
