david
I have a 90 C-30 with a Universal M-20 18hp engine. The engine has a tube or hose with a brass fitting from the bottom of the oil pan. Is this a factory installed item to drain the oil or aftermarket? Also does anyone know what type of oil extractor system is used with this tubing. Unfortunately I have not been able to speak with the previous owner as he now resides out of the country. Any info will be appreciated David
