When changing oil today in my 2gm20f I placed a piece of blue marker tape on the oil suction tube I inserted into the dipstick hole to match the depth of the dipstick. When removing the tube after sucking out the sump the tape remained in the sump. What type of problems can this cause? Will the filter pick this up? Should I remove the sump cover and try to retrieve that way?
Appreciate all responses. I still can't believe I did that.
Thanks, Jerry
Thanks, Jerry
