offshore sailing
14
Oday o'day 30 Lac Champlain
I have an o'day 30 and I want to sail it from halifax to bermuda an then to the carabeian I would be on the boat for 7 to 10 days to get to bermuda and 4 to 6 days to go Bahamas.
I don't want to go true the state cause I want to bring my bird and it is complicate to pass the US custom. Is it possible to doit with an o'day 30 1978 it seam to be a solid boat to do that cind of tripp.
Jun 9, 2008
1,850
- -- -Bayfield
Reading a spelling book along the way might proove helpful too. I don't believe the O'Day 30 is designed to be an A cliassified off shore vessel. Bermuda is quite alone out there and while the Bahamas are more protected, they are not for the feint of heart either and the further south to the Caribbean you sail, the bigger the water is too. Just so you know. Also you have to consider what capacities your boat has for long distance cruising. It is nice to have enough fuel to motor hundreds of miles between fill ups, lots of water supply, etc.
Dec 16, 2012
14
Sailing adventures
:confused:
I know that my writing is not too good cause I am French.
I am intend to prepare the boat for the trip I know that the hull and the finn are in one piece and the hull is pretty solid I did sail it in the tail of hurrican irenna and had alot funn The boat was handeling werry good butt had to slow it down cause of floting threes.
I want to putt a radar and a hf radio and know to work with sextan.
Feb 21, 2010
362
Beneteau 31 016 St-Lawrence river
Rigalio was there!
Salut nouveau propriétaire de Rigalio,
Since a quick check on the net shows Rigalio in the Bahamas but having gone down the ICW it evidently can make it to the Bahamas and back!
The boat can make it to Bermuda and the Bahamas in the right season... but do you have the knowledge and capacity to do it? Bermuda is a very usual first open sea destination. Since you wish to start from Halifax, getting to Halifax form Lake Champlain will give you a good idea of your capacities at sea.
There will be certain modifications to do to Regalio to make it seaworthy enough to brave the Atlantic. Your learning curve, since you are new to sailing, will be greater than the mods to the boat!
You will be much better off to learn seamanship than spelling for this endeavor. (sorry Barnacle Bill I couldn't resist the cheap shot, besides I surmise that Rigalio's English is better than your French).
You will need enormous amounts of preparation and become a Jack-of-all-trades to fix everything that breaks on the trip.
Good luck and fair winds
Catalina 380 16 Rochester NY
...nevermind the threes....it's the twos that will get you!
Couldn't resist either!
I was wondering, it's my dream to some day sail through Caribbean Islands and maybe farther south toward South America. What do you mean by the 'seas tend to get bigger as you go farther south'?
I understand the seas as you get to the Roaring 40's, just suprised to learn this!
Either way....Great dream Rigalio! Best of luck!
Chris
Jan 24, 2005
4,881
Oday 222 Dighton, Ma.
Smaller boats than an O'Day 30 have made such trips piloted by sailors who were just as determined as yourself with less knowledge and experience than you. I've always believed that it has to do more with the knowledge and experience of the sailor than just the boat he sails.
With that said, just make sure that you do all the necessary modifications to the boat along with preparations needed for the trip. While en route on your journey, always have a back up plan just in case your original plan fails. This applies to everything including parts, equipment, and destinations. I say go for it!
Good Luck Rigalio!
Joe
Dec 8, 2006
1,085
Oday 26 Starr, SC
Halifax to Burmuda
Good Luck Rigalio!
Joe
And you will need emergency life raft
with locator beacon in case your boat sinks.
Think of the Bounty of recent time...
Bigger boats such as 50 footers have
had extreme difficulty in the frequent
storms of this area of Atlantic.
Sometimes call 'Noreasters'.
And about your crew? Are they trained
in event you croak?
Forget the bird and sail close to the U.S.
coast. And live to tell us about trip.
On this forum check out contributor Roger
Long and ask him about your idea.
http://forums.oday.sailboatowners.com/forumdisplay.php?f=142
Since you will be sailing near Maine, ask Maine
Sail also a contributor on this forum.
http://forums.oday.sailboatowners.com/forumdisplay.php?f=135
But do tell us what you will do and if you
proceed keep us informed.
Ed K
1,085
Oday 26 Starr, SC
gear for trip
in event you croak?
Ed K
Check out this site for gear you will need:
http://www.landfallnavigation.com/safety.html
Ask our host, Capt. Herring, which gear he supplies...
Look here for your off shore life rafe:
http://directboats.com/rfdrevsup.html
Happy sailing,
Ed K
14
The route to get to Halifax will be Going down The St-Lauwrence River from Montreal. I know that if I can get true The St- Lauwrence with out problem
I will be abel to sail it any were. Cause it is the most dificult navigation course Cause of the tide and current. The boat will be readdy and will be equiped for the voyage.
Dec 8, 2006
1,085
Oday 26 Starr, SC
step the mast
Step the mast and go down the Champlain Canal. Just do not tell about the parrot on your shoulder...
Think of the distance saving...
Ed K
Oct 2, 2008
1,424
:confused:
My French friend, just wanted to give thank to commodore de grasse for saving our ass at Yorktown. Viva la France. ( forgive my spelling).
Oct 2, 2008
1,424
If it weren't for the French fleet at Yorktown we would all be Canadian. :)
Dec 8, 2006
1,085
Oday 26 Starr, SC
typical
Typical assumption based on assumed outcomes on events that did not happen.
Today this is called Monday Morning Quarterbacking.
It is analogous to assuming you cannot make it home in a sailboat without a motor.
Sailing a boat against the wind just takes time and work.
And I would tell our Canadian friend that I am about 30 miles from the southern end of his Great Lake and the Champlain Canal. There is water under the bridges! Imagine that!
The locks are waiting for him...
Ed K
Leicester, Vermont
