O'dDay 25 rudder and tiller repair
Oduy
Jul 25, 2018
8
Oday oday 25 Albany NY
Hello all, I have a 1975 O'Day 25.
I am currently in the process of sanding down my rudder then applying a penetrating epoxy then paint as it is in rough shape. When reattaching the pintles and tiller to the rudder should I epoxy the through holes and apply a sealant?
I also purchased a new tiller and wasn't sure if I should epoxy and seal the bolts that hold the the tiller bracket to the tiller?
Finally I am replacing a bad gudgeon and was looking for suggestions for a backing board for the gudgeons. I was planning on using weatherboard but am not sure where to find it so any suggestions would be great.
Ward H
Nov 7, 2011
3,786
When I worked on the rudder of my 25 the holes were elongated. I filled all the holes with epoxy and re drilled them to fix the elongation.
I like using G-10, a compressed fiberglass board, for backing plates. Easier to work than stainless steel. Available at www.mcmaster.com.
If you use wood, you should coat it in epoxy. A dense plywood would be best. Not sure if the weatherboard would work as a straight grained wood may split.
Good luck.
Oduy
Jul 25, 2018
8
Good luck.
Thanks Ward I wanted to avoid using wood. Now I can’t decide whether to use butyl tape or regular sealant for the gudgeons. I’m concerned butyl tape won’t hold up under the lower gudgeon.
Ward H
Nov 7, 2011
3,786
Butyl tape is great for deck hardware but not recommended for below waterline line use.
If I remember correctly the gudgeon is above the water line so should work well.
