A
Al
The line to the swing keel/centerboard on my O'Day 23 parted company. I've lifted the boat clear of the water and noted the "hole" in the centerboard near a notch. However getting under the boat will be tricky as well as getting someone on the boat (to feed the new line thought) as it sits on the lift. I would like to know the proper configuration of the cable/rope??? as it attaches through the "board". The cockpit end of the lifting rope is just that - a small diameter piece of line (like a small sheet). I suspect if I just re-ran the line and tied a stopper knot through the board the board might not full retract into its housing. A swaged cable loop through the hole? (seems mighty complicated for something that "should" have a simple solution.) Advice? TIA. Al
