O'day 39 Toerail replacement
564
Oday 39 Lake mills WI
I'm looking to replace a section of my toe rail. Does anyone know of a machine shop or yard with capabilities to fabricate toe rail?
Dec 2, 1999
15,184
Check the archives. There is a place where you can get the stuff made. I will look for it if I can remember.
Oct 10, 2006
492
Oday 222 Mt. Pleasant, SC
Rudy sells sections of it at drmarine.com. I made my own by ripping a similar profile out of ipe. I made mine slightly wider and taller than the original. Someone with a tablesaw should be able to do the same.
Oct 26, 2005
2,057
- - Satellite Beach, FL.
How hard was the Ipe to bend and work with? Beautiful wood.
Oct 10, 2006
492
It's definitely a tough wood but machines really well. It comes out of the tablesaw looking like it's been sanded. Which is good because sandpaper hardly makes a dent in it. Bending the toerail wasn't too bad. I just slowly bent it as I went along screwing it in. It's checking a little bit after being in the sun for a couple months but not too bad. I just have teak oil on it now. I haven't decided which route I'm going with the finish.
