In the water
Well , it's over.
Refurb is complete since I'm now doing what other boats owners are. Dreaming up the next gizmo to add or working on the repair list.
The last day:
Installed the windex backwards since we rigged the mast forward side down and never seemed the grasp it. We noticed it after the mast was stepped . Nice that the crane had a bucket.
Lifted the mast all the way up just to realize that it was facing the the wrong direction for the same reason.
Launched a 5'6" draft boat in 5' 6" of water with keel plates under it. Passed the simulated grounding test. (didn't really have this planned)
Forgot to place the speed transducer in the thru-hull. A real gusher!! and hart stopper.
forward head and seawater pump plugged. (likely wasps taking up home there) No one is using the head until next spring anyway.
I test ran the engine and then installed sound deadining material to the compartment walls. This work caused
- no power to the engine controls.
- wire loose and missing to the starter solenoid
- ground missing on fuel pump
- output hose on fuel pump leaking
- low water flow out of the exhaust
I expected at least some of this. It just took a few minutes to jump everything to get it started (is a diesel after all)and scooted over to the slip before things could warm up.
no leaks,
engine controls are a snap.
I bet I hooked something up wrong in the coolant system or the extra heat exchanger the previous owner gave me is plugged (par for course)
just got the canvas up when the sun popped out of the clouds just before sunset. I stopped work and took this photo.
Well , it's over.
The last day:
no leaks,
