Oday 34/35 vang
Sep 20, 2005
55
None None None
Anyone have a suggestion as to line diameter for the rope vang on an Oday 35? I can’t find a spec anyplace...
thanks!
dmax
Jul 29, 2018
1,362
Telstar 28 Buzzards Bay
Not sure what the original spec was but I used 5/16" because I already had some - it's fine but I would use 3/8" as I've done for the other control lines (outhaul, reefing) because it feels better in the hand.
Sep 20, 2005
55
None None None
Ok, good advice Dave. The previous owner had 9/16 on it...barely fit the blocks! 7/16 is what I’ll try...
Joe
Jun 1, 2004
8,360
The block size will determine max size, of course. However, it is not uncommon to see a smaller diameter, single braid line in the tackle with a cover sheathed over the handled, cleated portion (the cleat being near the cockpit rather than part of the vang itself). The smaller diameter line in the blocks will reduce friction considerably with no significant loss in strength. So you could take your 7/16 line and strip the cover to expose the 5/16 core which will run through the vang.. the cover remains on the portion of the line which is handled and cleated. It would work well with cunninghams also. Many rope manufacturers will UV coat their products core for exactly this reason.. MDX, Warpspeed etc. The opposite method is to start with a UV coated single braid, such as amsteel (dyneema) and sheath the handled part with a less expensive polyester cover.
Jan 7, 2011
6,017
Oday 322 East Chicago, IN
A bit off topic, but still about line size... my fairly new gaurhauer rope clutch (same design as original) is snagging my main halyard. The halyard is a bit smaller diameter than the OP had, but is spec based on the O’Day 322 owners manual. Today I replaced the “picked” halyard with a brand new one, 1 size larger diameter to see if it makes a difference....or should I just put the halyard in another one of the 4 clutches (and let it snag a line I don’t use nearly as often —reefing line for example)?
Greg
dmax
Jul 29, 2018
1,362
I was at my boat yesterday and what I said earlier was wrong - I have 3/8" line on the vang which is ok but I would use 7/16". The vang blocks are bigger than I remembered, I've been replacing the lines in the boom which has smaller sheaves and was thinking the vang was similar. Sorry about that.
Sep 20, 2005
55
None None None
Quite ok, DMAX...these vangs are not a usual concern. I’m getting 7/16.
dmax
Jul 29, 2018
1,362
Mister J - you don't happen to own Avalon do you?
wayneR
Jun 7, 2004
20
Oday 34 Cambridge MD
My vang failed last year and I had a new one spliced out of 3/8" double braid. Works fine with Schaeffer Pulleys and my deck organizer that leads the line to the cockpit.
dmax
Jul 29, 2018
1,362
Thanks - maybe I'll see you out there, mine is Interlude.
Sep 20, 2005
55
None None None
I’ll keep an eye out for Interlude! I spend a fair number of nights at Cutty and Tarpaulin Cove. See you out on The Bay somewhere or other!
