I have a '77 O'Day 322 that looks like there's rust coming from the starboard and port chainplates. How/what do I open up to inspect them?
Thanks, J. Geils
Thanks, J. Geils
Good catch Greg. Perhaps an O-Day 32? The interior pics of it shows a similar bulkhead arrangement.Sorry to say, but you don’t have an O’Day 322…they didn’t make them until 1986 or 1987.
On the 322, the chain plates are rods that are visible…
Greg
Good luck!Thanks, all!
I have found a rigger, I think. Fingers crossed that they can figure out how to open up and inspect and do the work.
On the 322, the chain plates are rods that are visible…View attachment 231025
I don’t know how to remove the wood cover on your chain plates. I see some plugs on the end, so if nothing else, you could drill them out and remove the screws holding the front piece of wood and see if that gets you access (but I think you will need to remove them completely to get full access.
Greg
==================================================================If it were me, there are a few things I would do…
1) remove the deck plates on each chain plate (those little screws hold the plate down on the deck) and seal up the cracks around the chain plates and the deck with butyl tape or sealant. Butyl tape is pretty tenacious and stays pliable for a long time. Might be harder to,get in the cracks though.
2) I would remove the wooden covers on the lower part of the chain plates and see what sort of damage you have…l don’t know how your chain plates attach to the hull. Some are bolted to a bulkhead (yours don’t appear to be). Mine are rods that extend down to the hull behind the settee back. You really need to know if the leak caused any damage to the strength of the chainplate attachment.
3) Think about removing and inspecting the chain plates…this could be a can of works but if you are in salt water, the plates could have started corroding. They are around 50 years old…so they may need replacement.
