Konstantin - in Russia a new commentator
Konstantin:
I just reviewed all the posts about your problem. Joe is usually a source of good and helpful information.
In reviewing your comments, the expense of getting new rudder seems to be issue.
The comments indicate difficulty in repairing foam filled rudders. Difficulty does not mean impossible if careful study and planning are done.
I would follow recommendations to remove rudder for repair. Completely dry it out. Cut it open as best you can around original seam.
With two halves exposed, remove all rotten or water damaged materials. Evaluate if both halves will go together or joined easily. If not, modify sides so that after interior repair they can easliy be joined together flush as possible.
The suggestion of using balsa wood to fill any voids sound good, if it is obtainable in your location. If it is not tell us what is that you would consider using and will collectively will comment.
After interior repairs are made to rudder, you will use epoxy to glue two sides back together. After two sides are glued together, you will make 10 or more thru the rudder holes. They will be countersunk at ends for fairing. You may use stainless steel bolts to bolt glued halves.
Alternatively, make epoxy fiber reinforced hole fillers to act as frp bolts to strengten holding two halves together.
If you choose stainless steel bolts, make sure that they are below surface so that you cover with epoxy, seal and make watertight.
Make sure that all bolt holes going thru rudder are redrilled larger and filled with epoxy then drilled to original size to insure no more water intrusion.
Here is a helpfull web site that contains much frp repair information:
http://www.epoxyworks.com/
Ed K
O'Day 26
[/left]
Thank you! It's very useful information for me!
[/left]
