Oday 302 shower sump
5
-O'DAY -302 westport
was wondering where this might be located and how to clean it out .May have gotten some bs from a reapir job in it.
Jun 2, 2004
297
Oday 35 Staten Island, NY
Anything like a 322?
I'm not sure about the 302, but if the layout and setup is anything like a 322, the sump pump is located in the vanity cabinet in the head, under a screw-out panel. On my boat, it's a pain to get to, mostly involving a lot of inhuman body contortions in a small space, but a relatively easy fix beyond that. In the cabinet you'll find the diaphragm pump, the inline water filter and most of the hoses (except for the short length that runs to the drain hole in the floor of the head).
Good luck.
Pete
s/v EmmieLou (O-322)
Little Silver, NJ
Oct 30, 2008
16
Oday 302 Kansas City, MO
My 302 is set-up the same as the 322, except our head is starboard and I think the 322 is port.
Whenever repair is needed in there, my daughter is gracious enough to "volunteer". You'll need a couple small flashlights, and I found a mechanics mirror to be useful.
Repairs are easier on cool days ...
Jurgy
'89 302
Apr 30, 2008
41
in between boats for now Plattsburgh Boat Basin, Plattsburgh, NY
302 shower sump pump location
On my 1987 302, the pump motor is located under the starboard settee close to the icebox/chart table.
Jul 12, 2011
148
Oday 302 st pete
Hey guys, I have an 87 302 that has had the sump removed so now the shower drains to the bilge. I'd love it if you could answer a couple questions.
1. In the cabinet below the sink, I notice the drain is routed out the hull(above waterline), but with no thru-hull. Is this where your sum pump drains as well?
2. How in the world do you access the drain hole for the head floor soas to attach a tube to it!?
3. Can you full explain your sump system layout to me, such as locations of pump, tubes whatever else may be involved?
Thanks
