Hey guys, I have an 87 302 that has had the sump removed so now the shower drains to the bilge. I'd love it if you could answer a couple questions.
1. In the cabinet below the sink, I notice the drain is routed out the hull(above waterline), but with no thru-hull. Is this where your sum pump drains as well?
2. How in the world do you access the drain hole for the head floor soas to attach a tube to it!?
3. Can you full explain your sump system layout to me, such as locations of pump, tubes whatever else may be involved?
Thanks
