O'Day 30 Rub Rail
Madeline Loretta
Has anyone any information on where to obtain a new rub rail for an O'Day 30. It is broken in several spots and it would be difficult to repair.
Don Evans
Tips
When you buy your replacement rub rail from Rudy, here are some tips I had squirelled away in my archive, written by Mike Burwell to another O'Day owner. Mike owns a 25 and lives in Florida. "1) Have a supply of extra screws on hand before you start. Some of the old ones will be bent or have the recesses for the bit stripped out. 2) If possible have two drill motors handy.....one with the screwdriver bit and one with the proper drill bit. 3) THIS IS A BIG ONE! Before starting the replacement, take a small square or level and draw a vertical line from each of the old holes with a pencil. Make the line long enough to show above the upper edge of the rubrail base molding. Then, when you start to install the new piece just push the base into position and drill a small hole through the center (in the groove) in alignment with the pencil marks. I'm guessing out of 130 or 140 screws we missed the old holes twice. 4) Be sure to put a generous dollop of 5200 in and on top of each hole before you put the base molding in place. 5) Only use the hair dryer or heat gun on the back of the molding. Getting the front too warm will deform it when you go around the corners (or the bow) making installation of the black insert more difficult. 6) When working with a longer section, place the coil on deck and loop it around a stanchion or winch or stern rail. This will keep it out of your way AND keep it from scratching the hull. 7) Finally, the insert will shrink over time. If you get into this job at all, consider replacing the entire insert. Start it on the transom about 1 or 1.5 feet from the base molding butt joint. Then when you are all finished you can buy a little cover plate to cover the butt joint of the insert which has a hole on each side for a screw to tack down the end and hide any shrinkage." Hope it helps. Don
