Tips
When you buy your replacement rub rail from Rudy, here are some tips I had squirelled away in my archive, written by Mike Burwell to another O'Day owner. Mike owns a 25 and lives in Florida."1) Have a supply of extra screws on hand before you start. Some of the oldones will be bent or have the recesses for the bit stripped out.2) If possible have two drill motors handy.....one with the screwdriver bitand one with the proper drill bit.3) THIS IS A BIG ONE! Before starting the replacement, take a smallsquare or level and draw a vertical line from each of the old holes with apencil. Make the line long enough to show above the upper edge of therubrail base molding. Then, when you start to install the new piece justpush the base into position and drill a small hole through the center (inthe groove) in alignment with the pencil marks. I'm guessing out of 130 or140 screws we missed the old holes twice.4) Be sure to put a generous dollop of 5200 in and on top of each holebefore you put the base molding in place.5) Only use the hair dryer or heat gun on the back of the molding. Gettingthe front too warm will deform it when you go around the corners (or thebow) making installation of the black insert more difficult.6) When working with a longer section, place the coil on deck and loop itaround a stanchion or winch or stern rail. This will keep it out of yourway AND keep it from scratching the hull.7) Finally, the insert will shrink over time. If you get into this job atall, consider replacing the entire insert. Start it on the transom about 1or 1.5 feet from the base molding butt joint. Then when you are allfinished you can buy a little cover plate to cover the butt joint of theinsert which has a hole on each side for a screw to tack down the end andhide any shrinkage."Hope it helps.Don
