update
Well I figured out the valves and plumbing, but the bilge remains an issue. I somehow got water in the boat bilge - happened after I filled the fresh tanks, but could be a bad hose on the engine as there was water under the motor. Anyway, the pump under the table in salon worked w/ new wires so old wires or switch was bad. Unfortunately that pump just took the water aft and not out so maybe there's another pump back there that's not working. Dry as a bone now but need to either find other pump or get a line under deck to back to set up a hose to pump it out.
