Oday 272 Rig tension
12
Oday 272 Great South Bay
Does anyone know what the rig tension should be on an Oday 272? Im not positive on the shroud diameter, If anyone has this boat or knows of it, please advise.
Dec 8, 2006
1,085
Oday 26 Starr, SC
Pat,
On boats this size the tension is by hand. Hand tighten and then one full turn. Keep in mind that too much tension can damage the cabin roof. There are many discussions of this in the archives.
Some people want to set the tension with a Loos gauge. On boats this size not used for serious racing, that is not necessary and can be damaging to cabin top.
The guy who helped me set up my boat was a serious and knowledgeable racer. After we got the mast up he wipped out his loos and set tensions. After he left, I reset to a reasonable feel.
It does not have to be perfect, just tight on the windward side.
Ed K
26
Sep 20, 2006
367
Oday 20 Seneca Lake
sounds easy, but the problem is how do you define "hand tight"?
i moor my boat on the open lake and it does get to rolling pretty good at times. i worry about the stays getting slack and then slapping back tight causing metal fatigue over time.
Dec 8, 2006
1,085
Oday 26 Starr, SC
Lord Nelson
Your question comes up all the time. I do not have an authoritive answer. However, if you read some of the manuals from boats of the mid 80's you get my method.
Also, if you ask experienced old time small boat sailors you get similar answers.
Then there are always the technocrats. Just remember that you can be so technical as not to have any fun.
I suggest that you check the archieves of this site and the Heart of O'Day site and read rigging instuctions from some of the old manual posted thereon.
Understand that my answer is not to imply I am an authority. I am just a Sunday afternoon sailor. I seldom sail to a destination. Just sail where the wind blows me.
Take any advice I offer for what it worth to you. In any event, rely on good judgement, not advice offered hereon.
Ed K
26
Sep 20, 2006
367
Oday 20 Seneca Lake
i also prefer low tech and just sail for the challenge to get from a to b with using just the wind. i have never used a used a gauge and usually tighten the rig so the stays are snug and the mast straight. i do get some slack on the leeward side when sailing in a moderate breeze. i just want to make sure i'm not doing something wrong since the boat spends so much time on the mooring rolling around at times 20-30 degrees.
