My O'Day 272 halyard jams up when hoising the main, about 6 inches from full up. As I inspect the system, I notice there are three sheeves ganged together on a piviting block, built into the base of the mast. The idea seems to be to allow the halyard to pivot and match the pull angle. However, the piviting block seems to be floating loose in it's mount and jams up when under tension. This prevents the main from hoisting fully without undo effort.
Does anyone know how it comes apart or if replacement parts are available?
Thanks for your help,
Mike
Mike
