i understand that Ed, I just don't have any contact information yet, or exactly what is available. When I do I will post it. This ain't my first rodeo pardner.
BTW. When I built that shed of mine, I ordered 2 by 12's for the trusses. They will hold 3980 lbs at the stringers if you strap over the top chord. Of course if the roof is covered with snow, that number would go down. I use two, ton and a half Coffing chain hoists and all the hardware and strapping is rated for 10+ tons. I wanted to be able to separate the trailers from the boats. I have found many trailers out there that are in less than safe condition. I also wanted to work on the trailer when the weather prevents sailing, ' cause the season is short up here in Wisconsin! It is also great to be able to lift another sailors boat so they can work as well. I need to find some full sized batts to get the insulation in for next winter. They are hard to find. The floor has Pex tubing in, so I'll rig up a boiler after the insulation. Gotta make some money first of course.
"A building greater than 100 yards from your home will improve your relationship with your spouse" <quote> Me
MikeB
MikeB
