rtrimmer
Looking forward in the bilge, there is/was a small piece of plywood fiberglassed in the bottom of the bilge. This is between the bilge opening and the fiberglass 'post' that is immediately below the compression post. The wood was very rotted and fragmented and is 90% gone. Does anyone know why this was put into place? Is it intended to support the cabin floor aft of the compression post and fwd of the bilge opening? Or is it simply a dam to prevent any water that accumulated in the bilge to not run forward of that point? Does this need to be replaced? Or is it no big deal... And if I replace it, should I create an opening that would allow any water forward of that point to drain into the bilge?
