Oday 22 structural question
Mar 2, 2019
679
Oday 25 Milwaukee
The compression post on our 25 was not glassed into the hull .It was glued onto the port bulkhead .
It wasn't difficult to separate and replace .The new compression post was saturated with epoxy for the first 6".
calone
Feb 24, 2025
9
Oday Oday 22 Bronte
Timm, you're right. It is glued in.
I will put tape all around and sand it in place.
The plywood color is too dark. Hopefully, sanding and a clear marine grade wood coat will open the brightness inside a little bit.
