Sogwap85
I just bought an O'Day 20. The mast is from Al-Spar / Kerwin
I don't know if this is the original mast or not but it sits on a stainless steel
U shaped tabernacle on top of the deck. I know that the tabernacle is a replacement from the original mast step. Because of the way the bottom of the spar is it does not fit flush and the whole mast is tilted aft about 10 degrees. The only thing I know to do is to cut off about 1/2 inch off the bottom to make it flush. The bottom of the spar is curved so that is why it is tilted. Any other suggestions?
Thanks
Thanks
