O'day 192 Centerboard Problem
Bob
Pendant rope twisted around centerboard and looking for suggestions on removal. Can centerboard be removed from the bottom of the boat?? no obvious access from inside the boat. Local marina"s will gladly lift boat from trailer ($$$$$$)and then what? How do you replace a centerboard??? Thanks in advance on any helpful hints
L
Larry
222Centerboard
We have a 222, but the 192 is almost the same. We needed to replace the centerboard rope and when we dove under the water to check it out, we also noticed that the centerboard was cracked open. So we had the 222 put on boat stands at a local boat yard for $10 a foot ($220). That included haul off of trailer, put on stands and haul back into water(was actually called a short haul)... Once the boat was on stands we easily accessed the bottom of keel and waa able to remove centerboard(three screws on bottom of keel), epoxy/repair it, replace the rope and paint the inside of keel where the centerboard is. All in all not a bad job, but have a second hand around to help and bring lots of tools with you. I will have photos of our centerbord removal soon, so if you want me to send them to you let me know...
