Haven't unwrapped the fiberglass insulation tape to verify but it appears that a nipple in the exhaust system has broken. On my boat the exhaust from the manifold flange to the wet hose connecting it to the muffler is 1 1/4" pipe which, while the engine has performed just fine, seems small. My question is replacing it with Sch 80 pipe vs Sch 40. Researching the archives indicates that Sch 80 is OK in general, maybe even preferred, but it is not quite clear to me what any experience is on the M25. I'm quite sure I'm going to find that the failure is at a thread right where it enters the elbow. If my research is correct, Sch 80 would be almost double the wall thickness at the threads. I'm considering replacing the pipe only (3 pieces - maybe 20" total length) and staying with Sch 40 elbows. My concern is the reduction of about 14% less open cross section in the pipe and the added back pressure on the engine.
Anyone with M25 experience or expertise on this?
