Observations
higgs
Aug 24, 2005
3,736
Nassau 34 Olcott, NY
1. Most boat work is cleaning
2. You cannot get something clean without getting something else dirty
Ross
Jun 15, 2004
14,693
Most cleaning is just moving dirt around. When I wash the dirt off my deck it goes into the river. When I pull up the anchor some dirt comes with it.
DannyS
May 27, 2004
933
Beneteau 393 Bayfield, Wi
True about the cleaning...
My recent observations regarding work are that work creates more work. I decided to attempt to replace the cutlass bearing this spring. Gotta pull the prop to get the shaft out, gotta pull the coupler to remove shaft, gotta replaced the packing in the packing gland, heck, while I'm in there, I may as well replace the shaft log hose...etc. etc.
Oct 22, 2008
3,502
- Telstar 28 Buzzards Bay
Simple boat projects rarely are as simple as we think they are... :) How often has the 30 minute project expanded to take three days...
Mar 22, 2004
733
Hunter 30 Vero Beach
Electrical projects seem to have that same outcome. I went to put a new terminal on a wire at the main panel, and ended up tracing and pulling out 50 feet of wire that led to no where. Eventually, the wiring that I pulled all came back to the panel. It was a big loop! I bet the wiring guy at Hunter Marine is still laughing his ass off.
Nov 6, 2006
10,217
Yeah.. the way I see it is that a boat is a couple of nice looking semi-permeable membranes that it is our jobs to maintain!.. The lower one keeps most of the seawater out and the upper one keeps at bay the rain (mostly) and solids like leaves, pine needles, and pollen and seeds. Lots of times in caring for those essential parts, we’ll find chinks that need attention. If we are lucky, we’ll not find them when at sea!
My goal has always been
to get things on board working properly so all I have to do is clean it and sail it. It took one year on our C22. It took four years on our C25. It took eight years on our C34. Do we see a pattern here?
higgs, you just burst my bubble! :):):)
Oct 22, 2008
3,502
Bigger the boat, longer it takes to do that.. .:)
Oct 10, 2006
492
Oday 222 Mt. Pleasant, SC
Boats grow when cleaning or repairing, but shrink when sailing
Dec 27, 2005
500
Hunter 36 Chicago
Sounds just like my weekend:
1. Clean the cockpit.
2. Wax part of the topsides.
3. Climb back into cockpit to grab some rags, dirty shoes leave tracks.
4. Clean the tracks off and wax somemore.
5. Cliimb back into cockpit to grab some lunch.
6. Clean the footprints off the cockpit floor.
7. Wax some more.
8. Climb back aboard to prep water tank.
9. Clean footprints from prepping water tank and draining faucets in cabin.
10. Repeat the above.:cussing:
Oct 22, 2008
3,502
Learn to levitate... ;)
7. Wax some more.
May 23, 2004
3,319
I try to get by with doing less these days. I am making covers for most of my woodwork so I don't have to constantly re-do wood. If it is broken I fix it and fix it the right way so that I don't have to fix it again, for a while. I try to replace major things before they break. I keep up on my maintenance.
Then some new thing comes out and I see the usefulness in it and I have to have it. It then takes time to get that up and running. It is a good thing that I spend a lot of time on the boat and I don't mind working on it.
I will take working on a boat over working on a house. Things just seem more basic and you see improvement much quicker!
Dec 1, 1999
2,391
Hunter 28.5 Chesapeake Bay
Don't forget that the object of your passion is called "sailboat," not "workboat." Sail first, clean later.
Oct 22, 2008
3,502
Unfortunately, some work has to be done before you can get to the sailing part... like re-doing the rigging, so you can put the mast back up.
Gary_H
Nov 5, 2007
469
Cal 2-25 Carolina Beach NC
My observation is that any work on a boat no matter how well thought out will require at least three trips to the hardware store before it's finished.
