Non-skid to smooth gel coat repair help?
10
Hunter 1980 27' Cherubini Lake Oolagah / Red Bud Marina
First post...great forum...
Greetings, our recently purchased sailboat has some crazing on both the starboard and port cockpit seating area that centers on the non-skid and moves into the smooth gel coat areas. It appears that a large object (or person) was subjected to the laws of gravity to cause this issue. My plan is to run a couple of stringers on the underside of the seats to add a little stability in hopes to prevent furture issues, BUT how do I make the repair transition from the non-skid to the smooth gel coat. I have done numerous gel coat only crazing repairs, but I am not sure how to approach this issue with the non-skid being the epicenter of the crazing.
Thanks in advance for the advice....
HC
Dec 2, 1999
15,184
HC:
Take a look at Kiwi Grip for the non-skid. You can purchase this by the quart (more than enough for the entire cockpit.
If you decide to use this stuff, I suggest that you make the finish rather agressive (double roll). Nice stuff and reasonable price.
May 27, 2010
10
Ok, I'll check it out....to prep would I sand all of the older texture down to smooth?
Aug 28, 2006
579
Bavaria 35E seattle
i've used kiwi grip. no need for sanding. it's a good product; but keep in mind it won't replicate your diamond pattern non skid. it rolls on with a stippled effect.
