Until you get the time to run #2 reef line, lower sail. Time the reef line through the #2 sail reef point and then proceed. You really are only using one of the reef points at any one time. The goose neck some times has only one hook point.
Once connected you raise the sail to set the reef.
The original B331 had specs for Whichard blocks to be mounted in rigs for both tack and clew reefs for the first and second reefs.
Our friend from Halifax may have a different main today, someone may have removed the blocks, but I believe there are provisions in the boom for reeling using lines. The USA models speced Neil Pryde sails. (There were in the boom roller furling ones, but the weren't applicable here)
I don't think they had any clew hooks.
BENETEAU 331
Page 32 of 73
Jan. 10, 2003
rev 02
Mainsail Specification and Technical Worksheet
Model Type:
Oceanis 331 U.S.A.
Sail Type:
Classic Mainsail Series 2000
“P” Dim:
10540
“E” Dim:
4350
Rake:
280
Area:
25.1 sqmt
Finished Dimensions
Luff:
10390
Leech:
11130
Foot:
4330
Finish Details
Material Type:
7.3 Challenge Dacron
Tack Detail:
40mm SS Ring with leather
Head Detail:
50mm S.S Ring with leather
Clew Slug/Car:
SLD 151
Head Slide:
Metal Seldon 661B
Clew Detail:
50mm SS ring with leather
Clew Reef 1:
34118 Wichard block on starboard
Side led through PG 23 ring
Tack Reef 1:
33118 Wichard block on starboard
Side led through PG 20 ring
Clew Reef 2:
Tack Reef 2:
34118 Wichard blocs on starboard
Logos
2 bullseyes
Battens:
4 x 30mm flat
Ben. Part#:
0807-0026
Bat. Lengths:
#1
770
#2
1500
#3
2200
#4
3000
#5
n.a.
Trim stripes:
2 x 3/8" green stripes
Tell Tale:
4: 1 at each batten
Leech Cleat:
241 Alum. With snubbing eyes
Luff eyes:
13-#3 eyelets
Luff Tape:
4" with 8mm rope
Insignia:
Yes
Leech Line:
4mm Dacron line
Sail Ties:
Yes, 3 x 2.4 mt ties
Reef Cleat:
2 x 241 Alum.
Bag Type:
Drawstring type “B”
Reef Hts. %
Reef 1
14.5%
Area:
19.28
Reef 2
33.5%
Area:
12.56
Luff Slides:
15- 661A Seldon slides
Foot Tape:
2" tape
Reefing slots:
None
Reef eyes:
7 # 3 eyelets
Mast Section:
Z-Spar: Z 501
Boom Section:
Z-Spar: Z 360
Tack and Clew Cutback Details:
A: 50 B: 000 C: 280 D: 000 E: 25 F: 280 G: 85
Drawing Information
Drawing
331-clm1
Drawn By:
Bob
Date:
6-6--01
Rev:
08071332-R0
