1990 Hunter, Yanmar 2GM20F.
Went to use the boat Saturday, and backing out of the slip noticed much less response than normal; just enough to get backed out. Went to put the boat in forward, and nothing. Then reverse; nothing. Left adrift. Managed to get back to the slip. Then checked transmission linkage, cable connection, lever movement on the transmission, all was working. Put it in gear, shaft was turning in both directions. Took it up to about 2000 rpm, and all looked fine.
Thought maybe prop nut and prop had come loose, and on return to dock, running the engine in forward forced the prop back onto the shaft. Hired a diver to check, and he said all was tight. Hauled out yesterday, and indeed all is tight; no evidence of any slippage and prop nuts are very tight and obviously haven't moved since last haul out.
So what happened? I don't know how these transmissions work. Is there some kind of a friction plate (like a clutch plate) in the transmission that could have been slipping? What should I be looking for? Something clearly is not right.
