New Stripes
Dec 2, 2003
210
Hunter 34 Forked River, NJ
I need to replace the sun bleached stripes on my H 34, I bought from Hunter the last time, any one know of a source? This is the stripe at the rail, not the waterline! Thanks in advance.
May 24, 2011
81
Marlow Hunter 40 Oriental, NC
Pretty sure you can get them on the hunterowners.com site. Click on the "Store" tab at the top of the screen.
Oct 25, 2011
576
Island Packet IP31 Lake St. Louis, Montreal
Or else find a local shop that does vinyl signs. They may be able to reproduce the stripes for you.
Cheers
Matt
Phil Herring
Alien
Mar 25, 1997
4,924
- - Bainbridge Island
I'm not sure how far back this policy goes, but dealers had the option to change the striping on boats they ordered. As a result it's all over the map and there's not much consistency in either size or color. If you want the same striping replaced note the color and put a tape measure against it to check width. We stock the striping Hunter used and most of the logo decals but we can't tell you how it was applied to your boat.
Oct 25, 2011
576
A hair dryer and a putty knife have worked very well for me in the past.
Cheers
Matt
Phil Herring
Alien
Mar 25, 1997
4,924
There are more theories on this topic than on motor oil. :) Click the search tab in nav bar and try searching "remove name" or "remove decal."
I had good luck getting a boat name removed with Easy Off oven cleaner and a scraper, but there are folks here who know a lot more than I do. The trick is patience; go slow and easy.
Dec 2, 1999
15,184
I have not had much luck with a hair dryer/heat gun.
If you have a wall paper remover/steamer this work good. Also there is a device called an eraser that work on a drill that is okay too.
If you decide to use a putty knife be careful not to damage the gelcoat.
Dec 19, 2006
5,832
Hunter 36 Punta Gorda
Remove
I used a hair dryer and plastic putty knife and my was easy but only 2007 sailboat,
the hard part is putting new strip on with being nice and even and not
wavey looking.
I used a pencil to mark a line to follow.
Nick
Dec 19, 2006
5,832
Here
I got my new perfect matching strip here from Phil and the striping has a clear coating that must be removed and before removing I went a pencil along the old strip to help put the new one back on and look straight and :eek: some boats look pretty bad with waving stripes.
Nick
Feb 6, 2013
437
Hunter 31 Deale, MD
I removed the original striping from my '84 H31 last summer. I used a heat gun and my thumbnails, then solvent to remove residual adhesive. It took 27 hours to do the job.
Dec 2, 2003
210
I started the stripe removal, I used an electric heat gun, a 3 inch putty knife, and a pair of leather work gloves. I got about 25 feet of stripes off in 3 hours.
Mark48
Mar 1, 2008
166
Hunter 34 Milwaukee
While washing my H 34 down prior to winter storage I was pressure washing under the rub rail to remove spiders and accidentially hit the blue stripe, it immediately was removed in the small area. My washer is a small electric unit but seems capable of removing a stripe a lot easier than other approaches. Worth a shot if you have access to a pressure washer.
