New sailor, 2 boat options, need quick advice.
Jul 1, 2026
2
Tanzer 29 Cleveland
Im not too sure of what to get for a sailboat. And wanted to know community opinions. Right now I’ve decided on a Catalina 30 or a Tanzer 29.
The Catalina is where I live and the trust selling it had a survey valued at 6k due to deck moisture. No current asking price, I must give an offer. I personally looked at the boat and the ground wasn’t springy nor hollow and only noticed some moisture near the mast and one side deck. The boat comes with new main and jib.
The Tanzer, I’d have to sail home about 100nmi, and I currently have the price around 9-10k. This one has no deck issues, and comes with gori prop, and newly manufactured sails as well as a spinnaker and cutter or Genoa I believe; it was owned by a racer who wants a faster boat.
Both have self tailing winches and other lifestyle upgrades; I am wondering if there is a clear winner or stay away red flag I should look out for within these options.
My goal is to sail the Great Lakes whenever I want, maybe weekend trip once in a while. Usually me and friends. I don’t care about being the fastest but I like versatility especially for low wind days. I’d like to keep it cheaper but also am conscious that cheap boats with problems have great expenses so that’s why I’m going back and forth between both.
Thank you so much in advance for anyone that answers!
Sep 24, 2018
4,778
Catalina 30 MKIII Chicago
The Tanzer is clearly the better boat but it sounds like a C30 would better suit your sailing style. New boats are popping up all the time. Be patient. You'll know the right one when you see it
Likes: LLoyd B
dmax
Jul 29, 2018
1,360
Telstar 28 Buzzards Bay
Can't go wrong with a good C30. You should determine if the deck moisture is going to be a problem - rot vs. just high moisture. The number of C30s and the online community make it the easier boat to own and repair.
Welcome to the Forum.
You give us two boats to compare, but we do not know their age.
You share that you know "how to sail", yet nothing about your ability to evaluate, maintain, or repair a boat.
In the blind, choose the boat that:
1. Keeps the water outside of the hull
2. Is ready to go sailing right now
3. You feel comfortable buying, and then spending 2 times that amount more on making it the boat you like.
Jul 1, 2026
2
Tanzer 29 Cleveland
Thank you everyone so far, I appreciate the help through this and realize I did leave out some context:
C30 is MKII from 1988
T29 1986 full fiberglass deck with some ply reinforcements.
I used to race dinghies when I was younger and have crewed on Ensign class and Tartan 30 races a couple times a season. (I don’t really care about full racing though, more of just go out and sail for fun).
I am an engineer, and never taken care of a boat however, I have also never taken a car to a mechanic, not had a contractor touch my house. If I can learn how to do something I will and I will probably spend more money to do it right. I guess in the fiberglass world I did make 2 wing surf boards.
Features such as self taking winches, upgraded propeller, instrument packages etc. should not drive the choice.
Jib roller reefing is an important upgrade and would make a difference to me. But the OP doesn't mention any difference between both boats so I'll assume they both have roller reefing.
But based on a sailboat data.com comparison of the Tanzier 29 and Catalina 30 MK III we see that the Catalina is significantly heavier with a higher sail area to displacement ratio and a higher displacement/length ratio (Tubbier). Otherwise they are similar.
I would expect the Tanzier to be a more nimble sailer but more tender. (Better have a good main reefing system). I think it has a smaller cockpit.
See a comparison here:
What about a comparison of the auxillary power train? Is there any clear winner there?
dmax
Jul 29, 2018
1,360
1988 means that is it s C30 MKII which has some nice improvements over the MKI. The C30 is a large 30 foot boat, the cockpit is huge and the interior is comfortable. A decent sailor as well. Catalina transitioned from using plywood in the keel stub in the middle of the 1988 run, later ones in the year are all fiberglass - this plywood can rot, pretty big job to fix that you should try and avoid. Pay particular attention to the keel bolts/nuts, make sure they haven't sunk into the fiberglass. And check the keel to hull joint on the outside. Catalinas are solid boats. The Tanzer looks interesting with a large interior but I am not familiar with them.
Sounds like you will have no problem maintaining whatever you get, it's mostly attitude.
Dec 7, 2018
256
C&C 27 Mk V Vancouver
...the Tanzer 29 remains a soughtafter hull in the Great Lakes and Maritimes due to its robust Canadian construction* and its balance of "big boat" features in a manageable, 29foot frame.
* ... 'cause, Canada Day! :waycool:
BarryL
May 21, 2004
1,127
Hello,
You need a lot more information before deciding which boat is better.
Engine - do you know anything about the engine on either boat? Inboard diesel? Manufacturer? How many hours? Any maintenance records? How do the engines look? Clean and neat or is one a rusted hulk?
Electronics - how do the boats compare? Are the electronics usable? Is there an autopilot that works?
It seems that boat boats have good sails - that is really great news. What about other canvas like a dodger or bimini? Those get real expensive if you need to add one.
How is the interior? Reasonable cushions? Functional lights? Pressure water? Water heater?
I don't know much about Tanzer. Catalina 30 have a very good reputation. Not a real good performer but a spacious, capable boat.
Good luck!
Barry
Evidently listing port doesn't agree with me about the Tanzer being tender. but I was comparing and commenting between those two boats based on the numbers. They are virtually the same, same width and same keel draft. The ballast for the Tanzer is 2,425 lbs and the Catalina is 4,200 lbs. Hull form stability counts but that Tanzer looks like it has pinched in ends (Kinda like the IOR boats of that era). If the width was carried back further, which is the style of today, I would consider hull form to be a bigger factor. But it isn't.
The Tanzer may be stiff in comparison to other boats of that era.
Tanzer had a reputation for building solid well performing boats. Construction was robust. The 29 came out just before the collapse of the boatbuilding industry in the late 80s.
The Tanzer will be a bit faster than the Catalina based on the PHRF ratings. The Tanzer comes in at 174 and the Catalina 30 mk II comes in between 180 and 210. The Tanzer should sail a little higher on the wind and be faster. The speed difference will be most notable in the light air conditions the Great Lakes often experience and might make a difference between sailing and motoring.
I owned a Tanzer 22 back in the day, so I'm a bit biased towards the Tanzer 29. I also prefer boats that are fun to sail, the Tanzer will probably beat the Catalina in that regard. Either boat has good potential the one to choose is the one in better shape and better maintained.
Apr 8, 2010
2,254
Given the info you have now about soft decks, ask when ALL the deck fittings were re-bedded. After approximately 20 years that will be the difference between a boat you can upgrade and enjoy, and one with constant leaks and core issues.
Jun 17, 2022
551
Hunter 380 Comox BC
Welcome to the forum.
Condition condition condition ....
Obviously, you're partial to both boats, so the major differentiator will be condition. You didn't mention the condition of the diesel engines, has there been a mechanical survey (takes about 2 hrs) .... corrosion and compression being the main concerns.
If one has soft decks, water intrusion or a surveyor detected high moisture content in the deck, do not buy that boat unless you are experienced with fiberglass repair, boat building and are willing to spend a lot of time grinding, sanding, filling, etc... It's tough work and you need a dry environment. Some yards require the boat hoarded when sanding. If you like a project and have the time (maybe you won't sail this year), then that could be an option..... just keep in mind that if the water ingress is too large, it may not be worth repairing. Surveyors use both percussion and sensors to detect motion. Usually one without the other is not a reliable test, they will often rely on both methods to estimate the condition of the laminate structure and presence of moisture.
Moisture in the deck anywhere is a critical flaw and if not addressed very quickly (within a few weeks of leak starting), it degrades the balsa core which turns to mush. Keep in mind that the cabin top is what keeps the boat from folding back on itself. It's just as structural as any other piece of the hull or rigging.
Racer tend to look after the important stuff (rigging, sails, steering, hull structure) but it might have some rash (gel coat scratches, gouges, etc....).
New sails, no deck issues. If the Tanzer has a clean survey, that would be the clear winner if that is the two boats you've narrowed it down to.
Do you know how to sail? That is step 1 BEFORE buying a boat.
Can you break down the 100 NM trip into 3 - 3 day trips ?
All boats have great expenses. Cheap boats, new boats, old boats, fancy boats, clean boats ..... Things just fail or we have an oopsie coming in to dock, a $150 winch handle falls overboard, an exhaast manifold and heat exchanger rusts out from the inside? That's a $2500 bill, engine mounts? $800-$1000 plus a day for your mechanic to install them and align the driveline, etc... Whatever you think your budget is for maintenance, triple it. Can you still live with that? If not, buying a boat is not right for you.
When people say Bring Out Another Thousand (BOAT), they mean it :)
That being said, there is no better place to spend a nice sunny Saturday.
Likes: maxi95
degas
Aug 14, 2023
77
Tanzer 29 Lake Ontario
T29 owner on the eastern end of Lake Ontario here. T29s are French-designed and Canadian-built. Yeah, she's tender when she's still but stiffens up under sail. It doesn't take much wind to get to hull speed and I often find myself reefing the main when the wind exceeds 10-12 knots.
I have the original Yanmar 2GM20. Stuff is acceptably easy to reach with access panels forward and aft of the engine. Other owners have an equivalent Volvo.
The cabin layout is superb, with closed vberth, aft head, closed aft cabin, and nice-sized galley. The settee includes 2 removable stools which I never use. There's already enough room around the table to seat 4 adults.
There's even still some support through tanzerboatparts.com, which is run and owned by Johann Tanzer's son.
I hope this helps.
