New owner of a 29.5
Apr 26, 2020
2
Hunter 29.5 Newport News
Assuming the survey and sea trial go well I will be a proud owner of a Hunter 29.5. I was wondering if there were any known issues I can ask the surveyor to look out for and I need to look out for my self. I am excited to start this adventure and look forward to learning and contributing to the community.
Feb 21, 2013
4,638
Hunter 46 Point Richmond, CA
...............I was wondering if there were any known issues I can ask the surveyor to look out for and I need to look out for my self................
Every boat is different........I've owned a Hunter 31, 386 and now 46 and each had different issues identified during the survey. Try to run all the systems (head, water, electrical, electronics, engine) and check condition of sails, running/standing rigging, canvas and safety equipment (fire extinguishers, engine fire suppression, USCG safety requirements). The surveyor take photos of areas of concern and document sailboat maf/model of engine, transmission, electronics, etc. These two articles might be of interest.
Sailm8
Feb 21, 2008
1,751
Hunter 29.5 Punta Gorda
The only issues I have had are leaks in the fixed ports and various hatches. These are to be expected.
Welcome @dbrooksatc to the fun of boating. Congrats on your new to you boat. (Assuming the survey goes well.)
A good survey will open all of the voids (cabinets/spaces) look inside to see if there are cracks, loose things, holes:yikes:. The surveyor would turn everything on on and off, pump it, rotate it, examine it. As @sail sfbay suggest a good surveyor should give you an extensive report. You might want to be there to observe and when something does not work as expected, note it down.
I see a surveyor as a resource to give me a second opinion on a boat. Then it is up to me to make a decision. With all this information will this boat take me safely to the places I want to go and get me back. If there are defects can I fix them, or pay the cost to fix them.
A good sailboat surveyor will give you an opinion of the rigging and the sails (sails are the power system of a boat - like a Motor is to a power boat). If the Surveyor is not skilled in this area perhaps you need a rigger to inspect that area Or take the sails to a sail loft to get an opinon of their condition.
On the old boat I bought I knew the rigging was suspect. I sailed here gingerly that first summer, then during the winter I refit the mast and all the rigging. The cost exceeded the cost of the boat. I had offered a price lower than asked anticipating the cost of refit. I was still 30% off. Having gone through that process I now have a boat worth more, and capable of taking me to the places I want to sail.
Hope this helps to provide some perspective. Good Luck.
Likes: sail sfbay
Feb 21, 2013
4,638
Ditto jssailem.....I might add that a marine surveyor is generally not a standing rigging or engine surveyor so if you want those additional inspections you will need to hire them out. That said, a sea trial, review of seller's maintenance log and oil and primary fuel filter bowl, if it has the latter, inspection will generally give you confidence they are OK. Depending on the age of the boat, a rigging inspection is good value for money unless the seller has already done that. When I sold my first 2 sailboats I provided maintenance documents and history and a standing rigging survey ($300) during.the offer. Be sure to inspect everything you cannot maintain with the boat in the water such as through hulls, shaft, strut, zinc and rudder, during the haul out.
