Welcome
@dbrooksatc to the fun of boating. Congrats on your new to you boat. (Assuming the survey goes well.)
A good survey will open all of the voids (cabinets/spaces) look inside to see if there are cracks, loose things, holes
. The surveyor would turn everything on on and off, pump it, rotate it, examine it. As
@sail sfbay suggest a good surveyor should give you an extensive report. You might want to be there to observe and when something does not work as expected, note it down.
I see a surveyor as a resource to give me a second opinion on a boat. Then it is up to me to make a decision. With all this information will this boat take me safely to the places I want to go and get me back. If there are defects can I fix them, or pay the cost to fix them.
A good sailboat surveyor will give you an opinion of the rigging and the sails (sails are the power system of a boat - like a Motor is to a power boat). If the Surveyor is not skilled in this area perhaps you need a rigger to inspect that area Or take the sails to a sail loft to get an opinon of their condition.
On the old boat I bought I knew the rigging was suspect. I sailed here gingerly that first summer, then during the winter I refit the mast and all the rigging. The cost exceeded the cost of the boat. I had offered a price lower than asked anticipating the cost of refit. I was still 30% off. Having gone through that process I now have a boat worth more, and capable of taking me to the places I want to sail.
Hope this helps to provide some perspective. Good Luck.
