New (for us) 1973 Catalina 22 and basic mast tuning
Sep 22, 2018
1,869
Hunter 216 Kingston
This is great, but again it assumes you have an adjustable backstay, which I don't, so I'm still not sure what to tension it to. :-/
Any actual “tension number value” on the forestay can also alter tension values in other components of the standing rigging, mast rake etc. In other words changing the “tension” in any one component that holds your mast up can/will effect the values in the other components. Here is a link to how complicated this can be
As you know the wire used can be of slightly different lengths and can stretch over time. You mention you think you might need new standing rigging.
If it were me I would first confirm that the lengths of the shrouds and stays are close to new. That info is in the user manual but I will post it below. If some of the components are way off it’s unlikely you can use the turnbuckles to adjust it enough.
So having said all of that I think what you really want to do is get out on the water and sail.
If you can rig the mast in your driveway or some surface where the boat is close to being flat like it would be in the water where the mast is standing straight (in column) and you can push on each stay and shroud and they don’t deflect very much then you can be reasonably sure the mast isn’t going to fall down.
Pick a light wind day <10 knots and get out on the water.
Observe the stays and shrouds and if they seem sloppy tighten them up some.
Hope this helps
11
Catalina 22 856 Utah Lake
Okay, maybe I'm just not understanding what it's telling me. When I look at that document the only mentions of stay tensions are as follows:
In the mast rake section "Tighten backstay until snug, no slack."
In the on the water section "Sailing upwind with moderate backstay on, sight up the backside of the mast checking that it is straight. " What is moderate?
In the sail trim sections: "Backstay should be adjusted so you have about 6” of forestay say."
I'm sorry, but I'm simply not understanding what they want here, I don't think I have enough background to understand it... :-/ I need someone to explain it to me in a way a dumb Soldier can understand... LOL
Sep 15, 2016
850
Catalina 22 Minnesota
@flipwalker ok I get what you’re going for I think but I do believe you’re headed in the wrong direction with tuning. It sounds like your new to sailing and the C22 so first you need to understand why tuning is important and when its needed.
First tuning is just rig tension. The most important parts are making sure your mast is straight and “in column” with the boat. This is done once with a tape measure when you set the boat up for the season and then checked if you’re going to race. So long as the stays are on the boat and the pins are in then the mast will stay up. Everything else is simply fine tuning of the boat. Generally a properly tuned boat will make about 2 deg. better to windward (or more) for racing. Having the adjustable backstay allows you to remove the head stay sag when making windward progress and then add that sag back in for better downwind performance. Our boats are a mast head rig so rake is set initially while the boat is in the water and the backstay adjuster has little or nothing to do with it as it is simply pulling against the head stay.
Those are the fundamentals and they become very important to racers. I know because I both race and cruise my boat. However it does not sound like you’re a racer at this point (the bug may bite). If you’re simply a trailer sailor looking for a good time don’t over complicate this. Rig the mast with all rings instead of cotter pins for all pins and turnbuckles. If your cables are bottomed out then yes thy need to be replaced. Will they come apart as soon as you take the boat out likely not unless you’re out in 15+ winds but most avoid this wind speed that I have encountered here. Set the backstay to be adjusted half way for its turn buckle length, attach the uppers and aft lowers and put the mast up. Then attach the forward lowers and the forestay (head stay). Use a tape measure to make sure the mast is straight from side to side. If you don’t have a tape measure then use the halyard making sure it hits the deck at the same point on both sides of the boat.
Next launch the boat and hang a weight (wrench works) from the mast to set the rake. Tighten the backstay and loosen the head stay till you have 4-8 inches of rake. This cannot be done on the trailer as the boat is not “on her lines” and floating properly. Most of these boats are stern heavy. Once the rake is set tighten the lowers so they are sung but not too tight. The goal is equal tension all the way around. Then tighten the forestay until its tight to eliminate as much head stay sag as you can without it being super tight. Go sailing and you should see the leeward shrouds all fall sloppy loose. If they are tight your rig is to tight so back them off a turn or so when you put the boat away and check them on the next trip.
At the end of the day loosen the forestay and the 2 forward lowers only to drop the mast. If you pinned the other turn buckles then you will not need to mess with them again for the season. It’s more to type than it is to describe by far. As for releasing the mast follow Stingy sailor and use the mainsheet or the boom vang to hold the mast. Pull tight and the shrouds should almost loosen up. If you want a quicker path go with the quick release turnbuckles from CD. There spendy but I can’t find them anywhere else.
Once you have done this once or twice you will be able to rig the boat in about an hour. I know because it take me about that long alone at the start of the season and I slowly get faster thought summer until the snow flies and I forget everything again. There is no need to use a tension gauge and tune the rig unless you want peak performance. If that’s the case and you want to start racing let me know. You’ll want that backstay adjuster and a few other things to get the boat moving faster. The C22 tech manual has some great article about getting max performance on these boats for the race course and I highly recommend them. If you really want an education join the association at nationals and just talk with the other sailors. It’s a family friendly group and a great time. You’ll learn more in a week with them than in 10 years on these forums.
I hope this helps and if you have other questions let us all know. Not many (any?) c22 racers here that I know of but there are on the FB group and a few other places when and if the bug should bite you. Have fun sailing and don’t sweat the small stuff.
Sep 15, 2016
850
Yup you're overthinking this. Shoot me a pm if you want to talk with your number and Ill give you a call later today if your still confused. :waycool:
Likes: flipwalker
May 21, 2020
11
Okay. So I'm overthinking it. Dumb Soldier explanation "Tighten the wires till they're not floppy and go have fun..." Got it. ;-) When I get my motor running I'll take it out and hopefully not lose my mast... Hopefully, that will be tomorrow, though the winds will be kicking up significantly tomorrow afternoon. I'll have to keep my eye on that to make sure I'm not having a first sail in 20 knot winds...
Thanks again to everyone for your patience with the new kid. As I side note I did just go out and measure several of my shrouds/stays(Didn't get them all because I was lazy and didn't disconnect the aft stay or shrouds), but everything I did measure appears to be relatively close to spec(forestay actually came up short, but that might have been because of the awkward way my wife and I were measuring...).
Philip
Sep 22, 2018
1,869
Hunter 216 Kingston
Philip
It looks like you are well on your way to the FUN part of this! :)
I would recommend patience in waiting for the “right” wind strength for your first adventures and make sure your motor is fully functional in case you or your crew feel uncomfortable.
Sliding along in light wind where everything goes smoothly Is what you want. The high wind adrenaline rush stuff should wait for a bit ;)
Likes: flipwalker
Sep 30, 2013
3,646
You'll pick it up just fine, Flip. I'm a dumb ol' dogface myself, and I figured it out somehow. :thumbup:
