different alloys?
Dale, Maybe it is based on a different alloy 302/304, as mentiomed in Moody's post. Have you been to the North sails web site? Try clicking on thier" One Design section", and click on the rigging for your boat. They do more of a visual on the forestay tension, than an actual measurement. I did talk to an rigging expert at North, Chad, and he said that you can do a visual, or you can measure the "sag" of the forestay by running another line down along the forestay, pulling it tight, and then measure the "sag" in the forestay from that line. North Sails say about 6" of "sag" in the forestay for light air, 3"-4" of "sag" for moderate air, and very tight and straight on the forestay in heavy air. I guess you could measure the tensions with your Loos gauge once the desired "sags" are met. Chad, at North Sails could not give me any numbers at all on the forestay tensions. I also can't, because I have never measured the forestay tension on my boat due to a foil/roller furler thats on my forestay. I go by imagenary line down the foil, to sight in my "sag". Due to the roller furler, my tension on the forestay is a little "harder on" most of the time, then I go by the "feel" of how she sails. I do take tension readings on all of the shrouds though. Dale, don't go to nuts over the numbers, sail and feel my friend! Jay
