Engine Mounts
Ken, I jacked each end, for the front, I jacked on the gearcase where it meets the block.. Changed the fronts then jacked the rear on the back of the oil pan and changed those.. I don't like having a big chunk of iron balanced, so I wanted to keep two mounts touching while messing with the other two.
Also note that there is a bump on the underside of the top plate where the stud is secured.. This will be the nearest point of contact with the lower plate vee ..
Attached picture shows the right front a couple of months ago.. it may have had 1/8" clearance from vee to underside of plate .. Looks better when looking at the end gap between top and bottom plates.
