New batteries and charger
DArcy
Feb 11, 2017
1,786
Islander Freeport 36 Ottawa
Some of the battery chargers I see say 30 Amps for 3 battery banks, 10 Amps per bank. What I really want is 30 Amps into one bank. I'm planning on just using an ACR to charge a start battery. Is there a simple, multi-stage, 30 Amp single bank charger available? Can the ProNautics 30 Amp charger put 30 Amps into a single bank?
Mr Fox
Aug 31, 2017
204
Marshall 22 Portland, ME
Is there a drawback in your setup to using a charger that would just charge all your batteries? Not passing any judgment on your approach just curious, I’m always looking to learn about different setups.
DArcy
Feb 11, 2017
1,786
I have multiple charging sources (shore power, solar, engine alternator) and need to be able to charge all banks from each source. I need an ACR to charge the starting battery from solar and engine so I can simplify and just charge only the main house bank from shore power as well, allowing the ACR to charge the starter.
Jan 5, 2017
2,464
That's the setup we have on Sun Gypsy. Seems to work well as we are out for 4 to 5 months each year and don't have energy issues. Boat came with AGM's. Not sure how old they are but are still going strong. Heart 50 amp charger, Balmar 80 alt. and 200 watts of solar. I added the solar, I think it's the greatest thing I've done to a boat.
Feb 6, 1998
11,722
I understand the appeal of AGM and the price from Batteries Plus seems pretty reasonable.
Does anyone have any experience with Firefly Oasis carbon foam batteries? Firefly International Energy - 12V G31 Battery
They are purported to be very tolerant of deeper discharges, have excellent cycling characteristics and can be left unattended for long periods. But they are not cheap.
I would urge you to go find the May and August 2015 issues of Practical Sailor where PSoC (partial state of charge cycling) was tested.. Suffice it to say there are major differences in the quality and deep cycling capabilities of AGM batteries. Pay close attention to the East Penn AGM's in that test. These East Penn batteries are re-stickered by Batteries Plus, NAPA, Sam's Club, West Marine, Sears etc. etc. etc.) They are not a good deep cycle AGM because they were designed as a dual purpose battery. If you want a high cycling battery from East Penn their GEL batteries are amazing, their AGM's, not so much.
The Firefly Carbon foam AGM's are hands down the best AGM battery to tolerate marine type use, and yes we install all of them and test them as they age.. They are also designed and intended to be cycled to 80% DoD something that renders most AGM batteries useless in a matter of months. The Firefly battery used in that article is still going strong, despite tons of abuse, (I even left it at 80% DoD in a hot garden shed (uninsulated black asphalt roof) for four months straight). Today, at 6 years old it is still delivering 99.3% of rated capacity (as of the last capacity test).
When considering Firefly keep in mind that you typically need one less battery than all the competitors, it will cycle longer, and in the end will be less costly, not more.
As for chargers we really like the Sterling ProCharge Ultra with its 5 year warranty and near impeccable reliability track record. We have sold many hundreds of these chargers and warranty issues are pretty much non-existent.
Likes: DArcy
