Needed - Jabsco Maserator Pump
O
Okiman
I need to replace the Jabsco maserator pump on my Jabsco electric marine toilet, model 37010-0000. The toilet is just fine but the motor is no good. I would appreciate it if someone could tell me where I can buy the entire motor unit without buying a whole new toilet. Thanks,
Dec 2, 1997
9,011
- - LIttle Rock
Best--maybe the only--way that makes any sense
A motor alone would cost you as much as a complete new toilet, and you're prob'ly not likely to find one anyway. However, you should be able to find the "base kit" (everything but the bowl). Or, you can upgrade to the Raritan SeaEra "conversion" (also everything but the bowl), which is a far more durable toilet, for less money. The SeaEra was designed to be an identical "drop in" replacement/upgrade for the jabsco 37010 series. To see both, go the jabsco site here: http://www.jabsco.com/prodInfoApp/servlet/ListTypes?categoryId=JMTOI&catalogId=Marine and click on "electric toilets and kits". The SeaEra conversion is here: http://www.raritaneng.com/products/toilets/electric/sea_era.html These folks usually have the best price: http://www.raritaneng.com/products/toilets/electric/sea_era.html
Tim McCarty
Hey Peggy...what about Wilcox Crittenden??
Specifically, does Raritan make a conversion kit for the WC Headmate??
Dec 2, 1997
9,011
- - LIttle Rock
Any bowl that has a 4-bolt + mounting pattern
Will fit the SeaEra conversion. However, the mounting bolt pattern for any electric toilet base will NOT match the mounting bolt pattern for any manual toilet base.
Dec 23, 2003
268
Hunter H31 83-87 Captain's Cove Bridgeport, CT
Call Jabsco
My Jabsco Maserator Pump failed last month, I called Jabsco and they sent me a new one FREE!!! Northeast Region Jabsco Service 11-35 Commercial St. New Bedford, MA 02741 Phone 508-994-9674 Fax 508-990-2785
